You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join RX7Club.com today!
Yes I have searched, but have not found an exact match to my problem.
The car: 85 SE all original, 80,000 km's on stock motor.
The idle problem I have is intermittent. The car will idle normally about 75% of the time and drives 100%, gas consumption is also good. Plugs, cap and wires are new.
25% of the time the car will idle at about 2k (when clutch depressed), if I release the clutch and sit in neutral the engine will go into a cycle bouncing between 1k and 2 k. (this is embarrassing when sitting at a light, hopefully it never happens beside a cop!) It sounds like I'm revving the engine like some street racer.
Also when at low speeds the car can lurch forward as the idle increases, I also need to back off on the throttle sometimes even when on the highway. So I know it is not just happening at idle.
Other than that the car runs perfect.
TPS?
Dirty Injectors?
Leak in the Throttle body?
I have read that if the throttle body is getting to much air the idle can cycle like I have described, I have also read about the TPS sensor. I don't think my injectors are dirty.
What about Sea foam, do you think that is worth a try first?
Adam
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on RX7Club.com!
1985 GSL-SE, red on grey, all original.
The surging I believe, can be treated by a good throttle body cleaning. The arms that hold the plate open or closed can get dirty and screw up the signal. I always clean everything around there with fuel injector spray with lubricants. Let us know what works for ya.
1985 gsl-se, K & N drop in filter, RB Header,MSD Blaster 2's
20 mpg
