Old 08-26-07, 01:45 AM   #1
Medicj02
Car won't start help
Hey...i think my s5 fc vert hates me or seriously wants me to dish out money that i don't have at the moment.....ok lets start from the begining but short story mode
First i bought this fc vert non running, i was told that the previous owner had messed with the distributor on it that's why it won't run ( i know there is no distributor)
Got the car home and after a few weeks of checking things out on it my dad replaced the trailing coil and it started up....lots of smoke came with it but he cut it off before letting the smoke clear some
since then havent been able to get it started.....and i've bought a different ecu, new spark plugs (even though it already had new ones), new plug wires.
just today i finished spending all day soldering in new connectors for the ecu since the ones that were on it had some oxidization on some of the plugs.....even then no start....
I have not been getting a spark......i have not checked for spark after i installed the new connectors but will be checking that tomorrow along with other advice that i get on here
the car has been sitting for about 2 1/2 years.....car will crank over but just won't start
Medicj02 is offline   Reply With Quote
Old 08-26-07, 01:48 AM   #2
Medicj02
oh another thing is....if you post something for me to try please give me a heads up on what to try next should that not work
i checked all the wiring in the car and all of it seemed to be in good condition other than the connectors that plug in the ecu
Old 08-26-07, 12:12 PM   #3
archangelkn
Rotorite
Send a message via ICQ to archangelkn
Well, if the car is getting spark and still not turning over, the next logical step would be to check your fuel system. Check out the FSM to learn how to do it.
archangelkn is offline   Reply With Quote
Old 08-27-07, 02:45 AM   #4
Medicj02
i'm getting spark.....everything in the fuel system seemed to have checked out except the fuel pump....so i'll be looking for one tomorrow.....anybody got any ideas on how to check and make sure a fuel pump is good, since i'll most likely be getting a used one
HTML code is On
Neutral start = okay, in gear start = jump... ? dwb87 2nd Generation Specific (1986-1992) 7 05-30-07 12:06 PM
rebuild won't start/cold start problem? unicorn_squad 2nd Generation Specific (1986-1992) 3 03-28-07 02:40 AM
Hard to start, and lots of wht smoke & then ez to start Joshatdot 2nd Generation Specific (1986-1992) 7 05-15-05 09:21 PM
Cold start Runs fine, hot start Crap! altf4 1st Generation Specific (1979-1985) 1 02-21-05 03:10 PM
injector duty cycle during a unsuccessful start/start attempt skunks 3rd Generation Specific (1993-2002) 0 05-07-04 11:30 PM
