The s4 turbo oil drain comes in right beside where the oil pump's drive chain/sprocket are spinning. When a chain in an oilbath spins, it slings off a shitload of oil in all directions. Since turbos require free drainage of their oil, and the outlet of this drain is right beside the chain, drainage could become an issue. So, mazda put a plate right between the chain and the oil drain...it is a thin piece of metal that bolts onto the 2 bolts on that side of the oil pump and keeps the oil slinging from affecting the oil drain.
The s5 turbo front covers moved the oil drain further out in front of the pump (to accomodate the larger electric OMP) and do not need this plate.
02 Denali: CHROME LIPS POKING OUT, THE TRUCK LOOKS LIKE IT'S POUTING...
04 RX-8: AT, 117k, appearance
90 Rx-7 T2: GT35R, HKS FMIC/BOV, AP PowerFC, Greddy PE dual
85 Corvette: out for paint
