You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join RX7Club.com today!
I detected another strange trail of liquid behind my car...
It seems to be water, not coolant, oil, or fuel.
I'm fairly sure it's coming from the little drain hose next to my exhaust manifold... is it safe to assume this is condensation from the air conditioner?
Is it bad if it's a fairly significant stream, and not just a few drops? My A/C compressor seems to have gotten squeaky as of late (probably a loose belt...).
Hope I'm not developing the Black Death or some other bizarre A/C problem.
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on RX7Club.com!
uhh
if it drips water, it means the AC is working right...
Originally Posted by South Park Pharmacy
Now, if it's more of a lucid, speedy kind of high you're looking for, I do also carry the Daytab Cold and Flu. Then there's the maximum-strength Cortitussin Cough and Cold, but of course, that's only if you really want to trip balls.
^^ Yep.. that means that your air is getting down to dew point (34-35 deg) and water is literally falling out of the air that goes through your AC box.. the more humidity there is, the more will come out.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
