You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join RX7Club.com today!
93 VR Base - sold
Parts FS thread: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
02 MV Agusta F4S 750 Red/Silver - sold
06 Infiniti FX35 AWD Pearl White
00 Toyota Corolla CE ...lol-sold...
I have slotted rotors and they work perfectly! plus i never have to worry about them cracking like drilled rotors. Although the drilled stay cooler during high-speed braking.
93 touring with Power FC, Greddy Profec B, Supra fuel pump, Apexi Intakes, XS Power smic, PFS DP, PFS cat back, RX7Store mp, Gotham short shifter, ACT clutch, Koyo radiator, Greddy RS BOV plus much more...
Performance Parts, Dyno Tuning, Rotary Engines. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
if u get drilled...get quality drilled because anything else will develope little cracks that stem from the drill holes.
I had drilled/slotted all around on the car untill the front started cracking and giving me problems. The rears had no cracking , probably because the fronts do most of the work. I ended up getting just slotted replacements for the fronts and havent had a problem since.
dont get them from ebay because i supposodly bought some brembo ones but they always made loud squeeking noises even with new pads, so i just picked up some power slots and theyre pretty dank
93 base rx7- mazdatrix streetport, ra super seals, 850cc primaries, 1300 secondaries, pos leaky bnrs, r1 dual oil coolers, fluidyne, asp med, showa coilovers, power slot rotors, rx7store dp, smb res hi flow, pfs exhaust, pfc, fc1k
Gotham Racing has some very affordable drilled or slotted or drilled and slotted rotors. You can chose which you want.
gothamracing.com
not 100% true, my friend got a set about a year ago and he still using them.. no squeeking or anything that iv heard of
