Old 06-20-07, 07:52 PM   #1
beefhole
Got a problem here...
beefhole's Avatar
Send a message via AIM to beefhole
Question Name these mystery wire connections!
Hello there! Each day is a new adventure with my 87TII and I have finding things to tidy up and get rid of. Near my passenger headlight, I have this round white connector with 6 blue wires going to it. What are these for? Also you can see 4 whitish wires were cut from the harness. What were these for?
thanks!
87 TII - Greddy TD06-20G + FMIC + Type RS BOV, 550/1600, Walbro 255, 3x MSD-6A, Autometer Oil + Water + Vac/Boost, Innovative LC1, Stoptech Slotted Rotors, Hawk Pads, Haltech E6K
Built by me. Tuned by me.
beefhole is offline   Reply With Quote
Old 06-20-07, 08:04 PM   #2
jasons7
jasons7's Avatar
That white round connector looks just like the one going to the headlight motors on mine. I disconnected them though.
to boost is bliss. to boost a 1.3 is divine.
jasons7 is offline   Reply With Quote
Old 06-20-07, 08:11 PM   #3
beefhole
beefhole's Avatar
Actually I should mention all my lights work fine
Old 06-21-07, 01:44 AM   #4
boost_its_what_for_dinner
RotoriousRx7
boost_its_what_for_dinner's Avatar
idle mixture?
fuel pump crap?
injector resistor box?
boost sensor?
take a picture from higher up and from the firewall facing foreward...
boost_its_what_for_dinner is offline   Reply With Quote
Old 06-21-07, 02:00 AM   #5
scrip7
Rotary Gearhead
scrip7's Avatar
Fuel pump resistor pack???......may have done a pump rewire mod.
1988 Sunrise Red TII, streetport, s5 hybrid t04s, A/W i/c, Walbro, MS2 v.3.0
1988 Sunrise Red Vert, s5 conversion underway...
1990 Blaze Red GXL daily driver, FD alt, RB downpipe/presilencer, Miata shifter
scrip7 is offline   Reply With Quote
Old 06-21-07, 02:04 AM   #6
scrip7
Rotary Gearhead
scrip7's Avatar
The whitish wires likely went to the strut actuators. Even if the car wasn't equipped with electric suspension, several models had the connectors near each strut tower anyways. Someone probably cut the short harness to the plug in favor of cleaning up the engine bay. Look at the opposite side strut tower to see if the connector is there as well. Similar whitish wires.
Old 06-21-07, 06:24 AM   #7
beefhole
beefhole's Avatar
I will try to get another pic.
Old 06-21-07, 07:42 AM   #8
scrip7
Rotary Gearhead
scrip7's Avatar
I looked at my factory wiring diagram and confirmed this for you. The white round connector with blue wires belongs to the fuel pump resistor/ relay unit. See the fresh electrical tape in your pic????.....someone has done the fuel pump rewire mod for you. And the whitish wires went to a plug that connects to the strut actuators if you had electric suspension. If yours doesn't, the connector would be there for it regardless.
Old 06-21-07, 07:47 PM   #9
beefhole
beefhole's Avatar
The connector was even there on the TII's for the suspension?
Actually that fresh electrical tape was done by me as the old was ripped and falling off Not just my pump was rewired, haltech baby
Thanks for the answers!
Old 06-22-07, 09:25 PM   #10
scrip7
Rotary Gearhead
scrip7's Avatar
Yep my '88 tII has the connectors, but no electric struts.
Old 06-22-07, 11:29 PM   #11
Chief
rotary adrenaline.
Chief's Avatar
Send a message via AIM to Chief
i would think the body harnesses on TII and GXL would be the same, because of all the accessories in common, and the harnesses on sport/luxury/base/(S4) gtu models would be the same, that way they can make only 2 harnesses instead of one per model.
87 base
5 lug, 17x7s, road race header, custom exhaust, RS*R down springs, KYB AGXs, reduced interior
, short shifter, centerforce dual friction clutch
one LT8S in the car... behind the seat.
and some other stuff.
Chief is offline   Reply With Quote
Old 06-23-07, 01:41 AM   #12
scrip7
Rotary Gearhead
scrip7's Avatar
Interestingly, I just worked on a '88 GTU model yesterday that had the strut connectors, but obviously no strut actuators. I was curious enough to pop off the console switch plate hoping to see a suspension switch connector tucked in there, but none to be found. Not a true plug-n-play setup for sure.
HTML code is On
Mystery wire to a n00b ih8rotary 2nd Generation Specific (1986-1992) 7 04-18-05 01:15 PM
Mystery Wire? Pic Inside Saner 3rd Generation Specific (1993-2002) 12 03-27-04 07:32 PM
front speaker connections mystery! ryb2001 Interior / Exterior / Audio 5 03-12-03 11:16 PM
Mystery Wire? faye x7 1st Generation Specific (1979-1985) 4 02-05-03 05:17 PM
Mystery Wire- What is this for? (PIC) SomeDude 2nd Generation Specific (1986-1992) 9 01-27-03 03:34 PM
