Old 06-19-07, 04:58 PM   #1
TweakGames
PT-67 turbo FOR SALE!!!!!
TweakGames's Avatar
front cover removal - keeping timing tricks?
Hi all.
Situation: Taking the front cover off of my s4 t2 engine and putting it on my s4 NA because I am making it turbo, and want to have the front cover for the oil return. I have never messed with timing and such.
Question: Do you know of any tips or tricks to keep the timing correct (perfectly stock) while changing front covers?
Thanks.
Sub-question: Does the stock oil pressure sensor port/hole have enough pressure to split (Y) the connector and run that as the oil line to the turbo? Or do I need to get an oil pedestal adapter?
Sub-Thanks.
~Tweak
(For Sale) 13b-RE housings and rotors , PT67, balanced, 1600:550, SPEC stage 2+, aeromotive fpr, tial 38mm wg., exhaust, koyo
TweakGames is offline   Reply With Quote
Old 06-19-07, 05:15 PM   #2
micah
Winter sucks
micah's Avatar
Send a message via AIM to micah
The CAS controls timing... and since everything is keyed, you won't have to worry about it too much. When you put the new front cover on, you will need to line up the CAS the same way you normally would (check FSM for procedure).
I would say no,but maybe, on the oil pressure thing... For an accurate reading, you should get an oil pedestal adapter.
micah is offline   Reply With Quote
Old 06-19-07, 05:29 PM   #3
TweakGames
TweakGames's Avatar
Well I'm not to worried about the reading, just getting enough oil to the turbo.
But I guess I will do it right the first time. Im tired of going through engines.
Old 06-19-07, 05:42 PM   #4
micah
Winter sucks
micah's Avatar
Oh! I thought you were going to use it for a gauge... I didn't read the part about the turbo.. I would definitely not use the oil pressure sensor line for the turbo. I don't know a whole lot about turbos.... but that is a pretty small hole.
Old 06-19-07, 05:50 PM   #5
TweakGames
TweakGames's Avatar
Hmmm k. Well the oil pedestal has the same size holes (just 2 of them), so maybe I need to figure out another way to get pressured oil to my turbo. :\
Or maybe it will be easier to drill and tap the pedestal for a larger hole. The lines going to the turbo are pretty small, but I will have to research more.
Thanks
~Tweak
Old 06-19-07, 06:04 PM   #6
micah
Winter sucks
micah's Avatar
Doesn't the front cover have a spot for just this purpose?
Old 06-19-07, 06:08 PM   #7
TweakGames
TweakGames's Avatar
That is the oil return. It has no pressure.
Old 06-19-07, 07:45 PM   #8
TweakGames
TweakGames's Avatar
Update: Ok, well I ordered the racing beat adapter that has one 1/8 hole, and one 3/8 hole. That should be big enough. Thanks for your help.
Old 06-19-07, 07:49 PM   #9
micah
Winter sucks
micah's Avatar
lol.. I didn't help.
Old 06-19-07, 08:39 PM   #10
TweakGames
TweakGames's Avatar
haha well ya you did. BBUUTT guess what?
UPDATE!: haha I canceled my order with RB, cause a friend of mine, (kompressorlogic) just runs his turbo oil line from the pressure sensor hole. He has no issues, so now I just gata find some semi special fitting to be able to Y it and still have my pressure sensor. He just uses high pressure fuel line. (4$ a foot here eeek) but I have some extra so I should be fine.
We will see how it goes.
Old 06-19-07, 11:56 PM   #11
patman
Resident Know-it-All
patman's Avatar
Send a message via AIM to patman
you can get braided stainless line on ebay for less than $4 a foot, and it is a hell of a lot better. if you guess the length close enough, you may even be able to get a used take-off from a race team that already ahs the -AN fittings on the ends....
87 TII 20B 575/481 untuned. designed by me, built my me, fabbed by me, tuned by me
02 Triumph SpeedTona
90 Tracker- off road monster
52 Piper Tri-Pacer
patman is offline   Reply With Quote
HTML code is On
front timing cover? lupin 2nd Generation Specific (1986-1992) 3 05-06-06 10:31 PM
any tricks to keeping you temps down when using ac? DREYKO 2nd Generation Specific (1986-1992) 2 04-02-06 03:07 AM
Front Cover removal SOIA 2nd Generation Specific (1986-1992) 4 08-04-04 10:33 AM
RE To REW front cover/timing silverpain Haltech Forum 0 06-20-04 07:06 PM
front timing cover regg25 2nd Generation Specific (1986-1992) 1 04-03-04 04:57 PM
