Go Back   RX7Club.com > Tech and Performance > Engine Management Forum > Haltech Forum
Old 05-28-07, 08:37 PM   #1
IAN
Rotary Reborn!
IAN's Avatar
Send a message via ICQ to IAN
E8 Boost transition map programming?
Running 550/1600.
Running sequential injection.
How much effect if any does the staging map have if you have the staging set to common mode to your transition. For some reason I have excessive rich transition or excessive lean conditions. Almost had it ironed out and a small change by a friend in the staging map cause it to go excessively rich were as it was lean then rich previously. The bar before and after transition appear when holding throttle at that range to be fine.
I've read the manual and as far as I can see its just another bar (between primary and secondary transition. Like say your transition point is bar 11 and boost is bar 12 it would be like bar 11.5) that adds injection on the way through transition and down through transition.
Is there any easier explanation. Setup tips? Its scary trying to drive around the track like this and extremely annoying driving in town.
Also does anybody have BAC settings for the E8?
Thanks,
Ian
1988 10th AE 400+rwhp
1989 Turbo II
IAN is offline   Reply With Quote
Old 05-29-07, 12:13 PM   #2
crispeed
'Tuna'
crispeed's Avatar
Send a message via AIM to crispeed
Originally Posted by IAN View Post
Running 550/1600.
Thanks,
Ian
That's why you need to put it on a dyno and not just any regular dyno but one with an inertia brake and get the 'staging' mapped out. That's the quick, safe and most accurate method to accomplish it. With the way how Haltech have the 'staging' setup on the E-8/11 presently, staging is much more accurate than on the earlier ecu's.
CRISPEED Rx-7 9.204@150.47
TRAVIESO RACING Rx-3 10.04@130.86mph ALL MOTOR
AWD MOTORSPORTS 8.75@163EVO8 GSR E85
AD TURBO 2JZ S2000 8.69@163 E85
CHARLES/RAW 2JZ S2000 8.7213@157
BIG DADDY PERFORMANCE SUPRA's MKIII 8.70@170/MKIV 7.95@180
crispeed is offline   Reply With Quote
Low transition boost cruiser 3rd Generation Specific (1993-2002) 7 07-12-04 10:59 AM
Primary boost great, after transition boost builds slow & then flutters SpeedracerRX7 3rd Generation Specific (1993-2002) 4 03-30-03 11:32 AM
AFC and Boost controller programming JoeRx7__ 3rd Generation Specific (1993-2002) 0 08-04-02 04:15 PM
low transition boost need some help. violator 3rd Generation Specific (1993-2002) 5 06-30-02 06:01 PM
low boost at transition? Silver93T Power FC Forum 9 07-25-01 08:19 PM
