Old 03-19-07, 12:50 PM   #1
macinslaw
Advice - FC3 S4 13B water leak
I took out my motor looking for a water leak in between the motor and the bell housing. There is a definite leak, pretty bad one, in that area. I checked the freeze out plugs and found that they are perfect. I sealed up the motor and poured in water, found no leak, checked all hoses, also no leak, but I replaced several anyway.
I put the motor back in, put in water and the leak is back in between the motor and the bell housing again. Motor was never started, cold in all instances.
Not super familiar with the cooling of the rotary. My question is, can water leak out of the rear main seal?
Thanks.
-Mac
macinslaw is offline   Reply With Quote
Old 03-19-07, 01:03 PM   #2
black_88
reverse panda
black_88's Avatar
did you check for a crack in the houseings or the irons.
black_88 is offline   Reply With Quote
Old 03-20-07, 12:42 PM   #3
macinslaw
No I didn't. Is this a common phenomona? Where are the likely suspects? Any assistance would be appreciated.
Thanks.
Old 03-20-07, 01:06 PM   #4
black_88
reverse panda
black_88's Avatar
im not saying there is a crack in there. but im just saying there might be a crack there because it might have over heated. or it chould be warped to where it dose not make a good seal. or I chould be wrong all together.
Old 03-20-07, 01:17 PM   #5
BlueTII
Banzai Racing
BlueTII's Avatar
Water cannot leak from the rear main seal, but it can leak at the tension bolts. For this to happen it would require the engine plates to be extemely warped and the seals on the bolts to be shot.
PH: (574) 594-2035
Email:
for engine rebuild quotes
FC & FD Oil Pan Braces now available
BlueTII is offline   Reply With Quote
Old 03-20-07, 02:55 PM   #6
macinslaw
That makes a great deal of sense. Thanks a bunch.
-Mac
HTML code is On
