Old 12-02-06, 07:00 PM   #1
jetgelneo
jetgelneo's Avatar
using jdm block question
does anyone know if i buy a jdm engine and just use the block, and swap all parts around the block from my old engine, will it work? is it the jdm block that is different? or is it just the wiring/ parts around the block? also is the transmission usable with an american motor? by the way it's a 88 turbo 2
jetgelneo is offline   Reply With Quote
Old 12-02-06, 07:31 PM   #2
Phantomhp
Phantomhp's Avatar
Send a message via AIM to Phantomhp
Actually you might as well do that. I have a JDM engine in my T2 and I had to swap almost everything off of it to my US version parts. The lower intake works unless you need the subzero assist or cold start assist port. If not then the JSPEC version does not have that port.
Other than that you can swap over everything else.
As for the tranny I had to swap a few parts off the US to the JSPEC tranny and it worked fine.
Mike
Phantomhp is offline   Reply With Quote
Old 12-02-06, 11:19 PM   #3
jetgelneo
jetgelneo's Avatar
Thanks! By the way how good is the JDM engine performing?
Old 12-03-06, 12:52 AM   #4
iceblue
RX Mechanic & Bartender
iceblue's Avatar
Send a message via AIM to iceblue
There identical except S4 does not have a EGR valve on the int iron.
iceblue is offline   Reply With Quote
HTML code is On
