Old 04-23-06, 04:22 AM   #1
ringo
Did anyone know about the AC problem?
Everytime i press the AC botton maybe half hrs later, my cooland alert will on.......
It seem like drink all of the cooland......
If anyone get any idea what was happend did my 87NA FC?
Thanks.
If possible I have you guys can PM me too.
ringo is offline   Reply With Quote
Old 04-23-06, 01:36 PM   #2
rx7b13
Indy RX Club
rx7b13's Avatar
Send a message via AIM to rx7b13
there could have been a short in there some where causing your buzzer to go off. and have you tried opening your radiator to see if there is coolant in there recently.
rx7b13 is offline   Reply With Quote
Old 04-23-06, 02:22 PM   #3
sar
Doin a rebuild.
sar's Avatar
Send a message via AIM to sar
AC has limited to nothing to do with your coolant alert. The coolant your ac needs is a refrigerant (freon/halogen) gas while the coolant light and buzzer refer to your water based cooling system. You cannot see AC refrigerant (other than bubbles in the little window.)
Check your anti-freeze levels/hoses, check your engine temp, is your car smoking? Any trouble starting? Do you smell something sweet? It almost sounds like your coolant seal is leaking coolant causing it to leak out the exhaust.
PMed too.
sar is offline   Reply With Quote
Old 04-23-06, 06:35 PM   #4
HAILERS
HAILERS
*****Did anyone know about the AC problem? ***********
No, but we do know about the water leak problem.
HAILERS is offline   Reply With Quote
HTML code is On
