Go Back   RX7Club.com > Tech and Performance > General Rotary Tech Support
Old 03-08-05, 06:10 PM   #1
M104-AMG
Answer to: What's in MMO ( Marvel Mystery Oil)
That's the Marvel of The Mystery oil. Actually this stuff is closer to Slick 50 ...
User account number (aid): 12414
Posted by Seattle Scott on 2001-05-30 19:15:43
In Reply to: Using marvel mystery oil... posted by GreenDoh 12v on 2001-05-30 16:12:52
than some may think. I know people that have used it for years. I have a can in my garage. They won't publish the ingrediants (at least they didn't used too) just like the Slick 50 people.
Basically you can add it to oil, gas and diesel as their advertisment shows :
Marvel Mystery Oil top cylinder lubricant gas and oil additive. A light-bodied friction reducing, wear-resistant, heat-resisting additive which produces no carbon or gum but a lubricating residue in combustion motors. Presents sticky hydraulic valve lifters and counteracts harmful combustion residues. Mystery Oil combats internal motor rust and corrosion, lubricates valves, piston rings and upper cylinder walls and eliminates valve sticking. Keeps rings free and reduces piston and cylinder wear to a minimum. Also keeps fuel pump and carburetor parts clean, eliminating need of frequent adjustments. Mystery Oil retards formation of power-dissipating motor deposits. Can be added to diesel fuels, crankcase oils, gasoline, as it protects every part against wearing!
But if we search for an MSDS sheet on it we see it's basically oil, mineral spirits and naptha.
Anyway, I'd doubt if you can hurt anything with it and you can probably clean a few things with it. I don't think I'd use it on a regualar basis but if you have something that's dirty, sludgy or frozen I'd say it's worth a shot.
One of the MSDS sheets I found :
MARVEL OIL -- MYSTERY OIL - LUBRICATING OIL
MATERIAL SAFETY DATA SHEET
NSN: 9150011264459
Manufacturer's CAGE: 95015
Part No. Indicator: A
Part Number/Trade Name: MYSTERY OIL
General Information
Item Name: LUBRICATING OIL
Company's Name: MARVEL OIL CO INC
Company's Street: 331 NORTH MAIN ST
Company's City: PORT CHESTER
Company's State: NY
Company's Country: US
Company's Zip Code: 10573
Company's Emerg Ph #: 914-937-4000
Company's Info Ph #: 914-937-4000
Distributor/Vendor # 1: NASTER SALE INC / DBA ACE TOOL CO
Distributor/Vendor # 1 Cage: 1X015
Record No. For Safety Entry: 001
Tot Safety Entries This Stk#: 003
Status: SMJ
Date MSDS Prepared: 01JUN91
Safety Data Review Date: 21FEB97
Supply Item Manager: CX
MSDS Preparer's Name: UNKNOWN
MSDS Serial Number: BLPGX
Specification Number: NONE
Spec Type, Grade, Class: NONE
Hazard Characteristic Code: F4
Unit Of Issue: EA
Unit Of Issue Container Qty: 1 QUART
Type Of Container: UNKNOWN
Net Unit Weight: 1.9 LBS
Ingredients/Identity Information
Proprietary: NO
Ingredient: KEROSENE (PETROLEUM), HYDROTREATED; (MINERAL SPIRITS)
Ingredient Sequence Number: 01
Percent: 30
NIOSH (RTECS) Number: OA5504000
CAS Number: 64742-47-8
OSHA PEL: 5 MG/M3 (MFR)
ACGIH TLV: 5 MG/M3 (MFR)
Proprietary: NO
Ingredient: SOLV REFINED HEAVY NAPHTHENIC DISTILLATE,PETROLEUM; (NAPTHENIC
BASE OIL DISTILLATE) CAS NO 64742-63-8, 64741-96-4.
Ingredient Sequence Number: 02
NIOSH (RTECS) Number: PY8040000
CAS Number: 64741-96-4
Physical/Chemical Characteristics
Appearance And Odor: RED COLOR LIQUID WITH MILD ODOR.
Boiling Point: 313F,156C
Vapor Pressure (MM Hg/70 F): 2 @ 68
Specific Gravity: 0.9
Solubility In Water: NEGLIGIBLE
Fire and Explosion Hazard Data
Flash Point: 140F,60C
Extinguishing Media: CO2, DRY CHEMICAL, FOAM, WATER SPRAY, WATER FOG.
Special Fire Fighting Proc: WEAR NIOSH/MSHA APPROVED SCBA & FULL
PROTECTIVE EQUIPMENT (FP N).
Unusual Fire And Expl Hazrds: DO NOT STORE OR MIX WITH STRONG OXIDANTS.
Reactivity Data
Stability: YES
Cond To Avoid (Stability): NONE SPECIFIED BY MANUFACTURER.
Materials To Avoid: OXIDIZING AGENTS.
Hazardous Decomp Products: NONE SPECIFIED BY MANUFACTURER.
Hazardous Poly Occur: NO
Conditions To Avoid (Poly): NOT RELEVANT
Health Hazard Data
LD50-LC50 Mixture: NONE SPECIFIED BY MANUFACTURER.
Route Of Entry - Inhalation: YES
Route Of Entry - Skin: NO
Route Of Entry - Ingestion: YES
Health Haz Acute And Chronic: EYE: MILD IRRITATION. SKIN: ONE OR MORE
COMPONENTS OF THIS MATERIAL MAY CAUSE SKIN IRRITATION. PROLONGED OR
REPEATED CONTACT MAY CAUSE REDNESS, BURNING AND DRYING AND CRACKING OF THE
SKIN. INGEST: PULMONARY ASPIRATION HAZARD IF SWALLOWED. DO NOT INDUCE
VOMITING.
Carcinogenicity - NTP: NO
Carcinogenicity - IARC: NO
Carcinogenicity - OSHA: NO
Explanation Carcinogenicity: NOT RELEVANT
Signs/Symptoms Of Overexp: SEE HEALTH HAZARDS.
Med Cond Aggravated By Exp: NONE SPECIFIED BY MANUFACTURER.
REMOVE TO FRESH AIR. SUPPORT BREATHING (GIVE O2/ARTIFICIAL RESPIRATION) (FP
N). EYES: IMMEDIATELY FLUSH EYES WITH POTABLE WATER FOR A MINIMUM OF 15
MINUTES, SEEK ASSISTANCE FROM MD (FP N). SKIN: FLUSH WITH COPIOUS AMOUNTS
OF WATER. CALL MD (FP N).
Precautions for Safe Handling and Use
Steps If Matl Released/Spill: RECOVER FREE LIQUID, ADD ABSORBENT TO SPILL
AREA.
Neutralizing Agent: NONE SPECIFIED BY MANUFACTURER.
Waste Disposal Method: KEEP PRODUCT OUT OF SEWERS AND WATERCOURSES.
DISPOSAL SHOULD BE IN COMPLIANCE WITH FEDERAL, STATE AND LOCAL LAWS.
Precautions-Handling/Storing: KEEP AWAY FROM HEAT AND OPEN FLAME, CONTAINS
REFINED PETROLEUM DISTILLATES, IF SWALLOWED DO NOT INDUCE VOMITING, IF
INGEST CALL MD IMMED.
Other Precautions: NONE SPECIFIED BY MANUFACTURER.
Control Measures
Respiratory Protection: NIOSH/MSHA APPROVED RESPIRATOR APPROPRIATE FOR
EXPOSURE OF CONCERN (FP N).
Ventilation: MECHANICAL VENTILATION AS NEEDED.
Protective Gloves: CHEMICAL RESISTANT GLOVES.
Eye Protection: CHEMICAL WORKERS GOGGLES (FP N).
Other Protective Equipment: USE CHEMICAL RESISTANT APRON OR OTHER
IMPERVIOUS CLOTHING TO AVOID PROLONGED OR REPEATED SKIN CONTACT.
Work Hygienic Practices: NONE SPECIFIED BY MANUFACTURER.
Suppl. Safety & Health Data: NONE SPECIFIED BY MANUFACTURER.
Transportation Data
Trans Data Review Date: 97052
DOT PSN Code: LKZ
DOT Proper Shipping Name: PETROLEUM DISTILLATES, N.O.S. OR PETROLEUM
PRODUCTS, N.O.S.
DOT Class: 3
DOT ID Number: UN1268
DOT Pack Group: III
DOT Label: FLAMMABLE LIQUID
IMO PSN Code: LMH
IMO Proper Shipping Name: PETROLEUM DISTILLATES, N.O.S. o
IMO Regulations Page Number: 3375
IMO UN Number: 1268
IMO UN Class: 3.3
IMO Subsidiary Risk Label: -
IATA PSN Code: TJB
IATA UN ID Number: 1268
IATA Proper Shipping Name: PETROLEUM DISTILLATES, N.O.S.
IATA UN Class: 3
IATA Label: FLAMMABLE LIQUID
AFI PSN Code: TJB
AFI Prop. Shipping Name: PETROLEUM DISTILLATES, N.O.S.
AFI Class: 3
AFI ID Number: UN1268
AFI Pack Group: III
AFI Basic Pac Ref: A7.3
MMAC Code: NR
N.O.S. Shipping Name: CONTAINS KEROSENE AND NAPHTHALENIC PETROLEUM
DISTILLATES.
Additional Trans Data: PETROLEUM OIL,UN1270,3,III IS NOT A PSN UNDER IMO
AND IATA.
Disposal Data
Label Data
Label Required: YES
Technical Review Date: 21FEB97
Label Date: 22NOV91
MFR Label Number: UNKNOWN
Label Status: F
Common Name: MYSTERY OIL
Chronic Hazard: YES
Signal Word: CAUTION!
Acute Health Hazard-Slight: X
Contact Hazard-Slight: X
Fire Hazard-Slight: X
Reactivity Hazard-None: X
Special Hazard Precautions: ACUTE: COMBUSTIBLE MATERIAL. MAY CAUSE SKIN
IRRITATION. PULMONARY ASPIRATION HAZARD IF SWALLOWED. CHRONIC: PROLONGED OR
REPEATED CONTACT MAY CAUSE REDNESS, BURNING AND DRYING, AND CRACKING OF THE
SKIN.
Protect Eye: Y
Protect Skin: Y
Protect Respiratory: Y
Label Name: MARVEL OIL CO INC
Label Street: 331 NORTH MAIN ST
Label City: PORT CHESTER
Label State: NY
Label Zip Code: 10573
Label Country: US
Label Emergency Number: 914-937-4000
M104-AMG is offline   Reply With Quote
Old 03-09-05, 04:26 AM   #2
20Beast
Jeff20B's Avatar
In the MMO vs ATF argument, MMO wins.
Jeff20B is offline   Reply With Quote
naptha, un1268
Protek R and Marvel Mystery Oil. BoOsTin FD 3rd Generation Specific (1993-2002) 48 08-23-09 08:16 PM
metering oil pump adapter? pros and cons Michael Filippello 3rd Gen Archives 17 02-01-05 11:23 PM
Marvel Mystery Oil – Denny P.O.S. Racing 1st Generation Specific (1979-1985) 28 10-19-04 08:01 PM
Marvel Mystery Oil... mazdaspeed7 2nd Generation Specific (1986-1992) 26 12-07-01 03:31 PM
