power window switch
Old Apr 25, 2007 | 04:45 PM
DropTop7's Avatar
power window switch
ok here is whats happening. my windows are very slow when i press the button to lower them. passenger is slowest by far. but when i put power directly to the window it goes down like new. i cleaned the contacts on the passenger side and it still goes slow there seem to be no way to clean contacts on drivers side.....so is there a common place to look for a week connection in the wiring?
Old Apr 25, 2007 | 05:09 PM
jgrts20's Avatar
Who are you?
Its the master switch that does total control. I replace my pass. window switch with a new one and it still did it(pass. Slow). I was told its the master switch that needs the work. I will get to it someday on cleaning or replacing the master.
Old Apr 25, 2007 | 07:49 PM
rurouni2071's Avatar
wanderer
for the longer time I couldnt figure out why my pass side switch wasnt working.. had it aparrt twice and resoldered and checked everything... till I realized that they run in sequence.. so I redid the driver switch and good as new
Old May 9, 2007 | 10:35 AM
DropTop7's Avatar
what do you mean re did?
Old May 9, 2007 | 11:35 AM
jackhild59's Avatar
Rotary $ > AMG $
You can take the switch apart and clean the burned contacts. Use some extra fine sandpaper, maybe 400-600 grit. This is a temporary fix, as the protective plating is now removed. The contacts will arc and burn much more rapidly the next time.
Best permanent fix is to clean the contacts as above then add a relay for each window motor. That way the switch only carries the current needed to run the relay. The relay current is very very low (milliamps) compared to the current pulled by the window motors.
Old May 9, 2007 | 12:47 PM
jgrts20's Avatar
Who are you?
The driver side is the master, I replaced the passenger side one not knowing (at the time) it was only the master that needed to be replaced. My pass. window did the same thing!!
Old May 12, 2007 | 02:25 PM
iamsisyphus's Avatar
My passenger window won't go don at all, but the drivers side is good. Where are these switches located?
Old Jul 4, 2008 | 06:39 PM
badfun's Avatar
whats under the on off switch??
I was wondering if anyone can take a look at the picture and let me know if its missing a part. My pass side window won't go down the switch looks good I took it apart and cleaned it via the how to thread.what I'd like to know is my driver side switch missing a brass lever under the "on/off" button?
link
Old Jul 4, 2008 | 08:30 PM
Eple's Avatar
Epilepsy
CHECK THE FAQ/ARCHIVE.... -----> https://www.rx7club.com/2nd-gen-archive-72/power-window-switch-write-up-766218/
Badfun - you're missing the contact for the 'master on/off' switch that supplies the passenger side switch. If you don't get what I mean, look at this:
Old Jul 5, 2008 | 10:42 AM
badfun's Avatar
I figured I was, I just wanted to be sure. Do you think I can make one? That post helped me clean everything up what a great post.
Old Jul 5, 2008 | 02:25 PM
Eple's Avatar
Epilepsy
you might be able to, since it's just a larger version of the smaller 'bridges' in the switches.
You should be able to pick up another switch at a wrecker.
bURGRotary87
Aug 19, 2015 03:54 AM
