Old 06-19-05, 01:14 AM   #1
91mazdarx7
91mazdarx7's Avatar
Send a message via AIM to 91mazdarx7
about to buy electric fan need suggestion's
i'm about to buy an electric fan for my 1989 rx 7 turbo II who makes some good fan's that will allow the radiator to cool good and what size will i i have any charging issues on the stock alternator because it's electric i also got a mild sound system in the car so i don't know if it will stress it at all
looking for a FD for sale
91mazdarx7 is offline   Reply With Quote
Old 06-19-05, 01:16 AM   #2
Icemark
Play Well
Icemark's Avatar
Send a message via AIM to Icemark
My suggestion would be that you stick with the stock clutch fan.
There is not an electric fan made that will work without adding a 15-20 amp extra draw and realisticly to get into the same ballpark of CFM, you will need an electric fan that has around a 30 amp draw.
Most electrical gremlins actually sit behind the wheel when the car is on the road.
Give a person a fish, they eat for a day. Suggest they search before posting and they learn a skill for a lifetime.
Icemark is offline   Reply With Quote
Old 06-19-05, 01:23 AM   #3
91mazdarx7
91mazdarx7's Avatar
really well i have a fd alt i want to put in but i want to get a rotor shaped pulley from higgi but he only has silver left i'd like a red one. will i be able to get a e fan then since i'll be pushing more amps and should be able to run a 30 amp one then right
Old 06-19-05, 02:35 AM   #4
86GXL
86GXL's Avatar
Send a message via AIM to 86GXL Send a message via Yahoo to 86GXL
Efans suck... my stock fan NEVER came on and my car ran exactly 165F all the time. After installing an EFAN the temps will rise untill the fan turns on... its deffinatly NOT worth the hassle. Especialy when the car holds a good constant temp on the stock fan without it even turning on.
86GXL is offline   Reply With Quote
Old 06-19-05, 02:55 AM   #5
Syonyk
Send a message via AIM to Syonyk
Sentences! Punctuation! They exist for a reason... USE THEM.
Listen to Icemark. Unless you have a good reason for needing an efan, stay with the stock fan.
-=Russ=-
Syonyk is offline   Reply With Quote
Old 06-19-05, 03:13 AM   #6
zbrown
zbrown's Avatar
i guess the reason i went with the efan was to clean up the engine bay,.....stupid reason i guess
zac
zbrown is offline   Reply With Quote
Old 06-19-05, 03:34 AM   #7
Syonyk
Making space in the engine bay for intercooler pipes & such is a valid reason. Cleaning up the engine bay is also a good reason.
-=Russ=-
Old 06-19-05, 12:59 PM   #8
silverrotor
occam's razor
silverrotor's Avatar
91mazdarx7, a popular e-fan that I have seen alot of members run (myself Included) would be Flex-A-Lite's Black Magic #150. It has a maximum fan CFM of 2800! This Is easily accomplished with the FD Alternator btw.
silverrotor is offline   Reply With Quote
Old 06-19-05, 01:05 PM   #9
DylanShupe
Okay, I was born stupid..
DylanShupe's Avatar
Send a message via ICQ to DylanShupe Send a message via AIM to DylanShupe Send a message via Yahoo to DylanShupe
Looks really good silverrotor. Really clean setup.
DylanShupe is offline   Reply With Quote
Old 06-19-05, 01:08 PM   #10
silverrotor
occam's razor
Thanks, although my newer setup will have my EB having the same colour as the rest of my car. My FC Is currently In several million pieces and cannot be Identified as a FC when viewed at a quick glance.
It's always about principle
Old 06-19-05, 01:10 PM   #11
DylanShupe
DylanShupe's Avatar
How do you have your e-fan set up, like, how do you have it kick on?
Old 06-19-05, 01:13 PM   #12
silverrotor
occam's razor
I have It at a pre-set temp via a dial. The 2nd pic on the left side of all the wires making It's way back to the Fan Is where the dial Is. The probe sits snug b'n the fins of my Koyo at around the lower Radiator Hose.
Old 06-19-05, 01:22 PM   #13
DylanShupe
DylanShupe's Avatar
Nice
Old 06-19-05, 02:01 PM   #14
u-looz
u-looz's Avatar
my e-fan works great ... only pulls 9 amps and it pushes 2100 cfm. the best thing about it is i only paid $64.00 for the fan and 25.00 for the adj. fan switch ... and a strong battery will cure the extra load on your alt.. i think if you trust the work you do its worth it . i also run a R.B. underdrive pully and it all works great ... have part # if you all would like.
u-looz is offline   Reply With Quote
Old 06-19-05, 02:07 PM   #15
staticguitar313
R.I.P. Icemark
staticguitar313's Avatar
Send a message via AIM to staticguitar313
i'm kinda interested in running an electric fan b/c i'm looking into v-mounting when i go turbo, stock fan wont work then, out wise id use it without a doubt. i love the stock fan
staticguitar313 is offline   Reply With Quote
Old 06-19-05, 02:42 PM   #16
91mazdarx7
91mazdarx7's Avatar
i want to get a e fan because i'm going to get a v mount fmic when i get the money for one and also am cleaning up my engine bay.
Old 06-19-05, 02:46 PM   #17
91mazdarx7
91mazdarx7's Avatar
would you mind sending a link to where it can be bought for the cheapest it will hook up to the stock radiator right
Old 06-19-05, 05:13 PM   #18
silverrotor
occam's razor
Sure, I bought It at Sumitt 3 yrs ago. I see the cost of Inflation has gone up abit as I paid $30 cheaper than.
http://store.summitracing.com/defaul....asp&x=45&y=12
Old 06-19-05, 05:22 PM   #19
88t2romad
(_8(|)
88t2romad's Avatar
Send a message via AIM to 88t2romad Send a message via MSN to 88t2romad Send a message via Yahoo to 88t2romad
$199 eep! (plus shipping and handling to alaska)
88t2romad is offline   Reply With Quote
Old 06-19-05, 05:26 PM   #20
88t2romad
(_8(|)
88t2romad's Avatar
anybody have any other fans that work good also? otherwise i might end up with this one.
Old 06-19-05, 05:29 PM   #21
91mazdarx7
91mazdarx7's Avatar
that is a nice fan i will have to save up for it what all did you need to do on the installation it works on the stock radiator right
Old 06-19-05, 07:34 PM   #22
88t2romad
(_8(|)
88t2romad's Avatar
91mazdarx7, i just orderedthat fan, i should receive it in a week or so, after i install it ill maybe make a write-up. and ill tell ou hw it went.
Old 06-19-05, 10:09 PM   #23
91mazdarx7
91mazdarx7's Avatar
will i have any cooling issues with a flex a lite black magic e fan if i start pushing out 350-375 HP will it overheat this is with a aftermarket radiator to
Old 06-19-05, 10:18 PM   #24
silverrotor
occam's razor
I was golden right up to when I had Installed my GReddy FMIC.
http://www.rx7club.com/forum/showthread.php?t=316939
Old 06-19-05, 10:45 PM   #25
91mazdarx7
91mazdarx7's Avatar
so in that post with your problem it was that the space between the fmic rad annd e fan weren't sealed so the fan wasn't pulling air through the fins on the rad therfore it got hotter running right? i was planning on getting a cf panel anyways so you think i'll be fine as long as i got the panel
HTML code is On
