Go Back   RX7Club.com > New Member Section > New Member RX-7 Technical
Old 11-04-09, 11:40 PM   #1
Rx7_dR3aMer
New Member
Exclamation WELL...its an ANNOYING PROBLEM
well i finally register my car, and i go to the gas station and guess what? my gas lid won't pop open... and im just pulling and pulling the little lever and still nothing. so i call the guy i bought it from, and hes like
"yea that happened to me a few times just pull the lever harder and if that don't work shimmey the key in between the lid and it should pop open!" tried and failed
i looked up how to remove it, but i wanted to know if there something that could be locking the trunk/gas lid switch(both don't work) also if there are any other ways to get the lid open without well...breaking it
Rx7_dR3aMer is offline   Reply With Quote
Old 11-05-09, 12:08 AM   #2
mar3
oimoi ti draso teknon?
mar3's Avatar
Send a message via AIM to mar3
On the 1stgen RX-7's, you can reach under the carpet from the hatch area and the electric solenoid that pops the gas door actually has a bracket welded to it that looks like an "L"...you just hook your finger on it and pull. It mechanically pops the gas lid for you since you're pulling the actual plunger.
Hope that helps since I'm pretty certain you don't have a 1stgen...
Mario III
mar3 is offline   Reply With Quote
Old 11-05-09, 12:57 AM   #3
rx7nubie
Rotorite
rx7nubie's Avatar
happens to my 86 gxl all the time what i have to do is take my key or something around the same length and prop the lever up and then go and open the thing try this or have a friend hold the lever up. hope this helps
rx7nubie is offline   Reply With Quote
Old 11-05-09, 12:58 AM   #4
Damzil
Jam out with ur clam out
Damzil's Avatar
Send a message via AIM to Damzil
how the hell is it on the road without any gas??? I assume it's been sitting for a while, and the previous owner obviously knew what to do with it.
LOL wow that totally sucks I have the same model, but no problems like that. how ridiculous!
Damzil is offline   Reply With Quote
Old 11-05-09, 03:50 AM   #5
alex ruano
dj aztek
Question
i also have the same problem on my 1st gen
alex ruano is offline   Reply With Quote
Old 11-05-09, 02:57 PM   #6
Rx7_dR3aMer
New Member
Smile i fixed it mehself...
well i just went to the online manuel(which i give a BIG THANKS to whoever uploaded it) and found the actual steel wire and opened up the trunk, pulled back the felt and just pulled it my self, the fuel lid opened right up zoomed right to the gas station, i was on E...and pumped 46bucks full of fuel...
Old 11-05-09, 03:24 PM   #7
fc3si
Rotorite
fc3si's Avatar
46$?!
holy shit!
how much is gas in florida? i'm paying like 2.60 a gal for premium
myspace.com/yamnaes
Last edited by mar3; 11-05-09 at 05:27 PM. Reason: Killd quote since reply was back-to-back to post in question...
fc3si is offline   Reply With Quote
Old 11-05-09, 04:12 PM   #8
Rx7_dR3aMer
New Member
lucky mofo 2.75 for premuim here =(
